Problem z zaprogramowaniem regulatora
ANDERS
Niedawno kupiłem sobie regulator mystery pentium-80A. Nie umiem go zaprogramować za pomocą aparatury. Mam oto taką instrukcję:
Main Functions
1. Safety mode: the motor won't start no matter what the position of the control stick is when
switched on the RC unit.
2. Brake Setting: On/Off (factory setting is off)
3. Three point battery type and low voltage selection.
4. Software reversion of motor turning direction.
5. Low current protection: ignore/reduce power/shut off
6. Temperature protection: reduce power when the temperature reaches 120 degrees C
7. PWM frequency: 8KHZ/16KHZ
8. RPM setting: 20,000rpm/50,000rpm/100,000rpm (60A/80A Only)
ESC program procedure
Normal Start Up
When throttle stick is off, you will hear one Beep for Brake on, or two tones for Brake off.
Program
When throttle stick is at full power connect battery and switch on and wait for 5 seconds.
Setup mode isentered:
1. Brake: If you pull the stick to off within 5 sec Brake will be changed
(On ->Off or Off ->On)
2. Battery type: (Voltage Cut-off)
Ni-Cad . . . . .
2 Lipos(5.6V) .. .. .. .. ..
3 Lipos(8.4V) ... ... ... ... ...
4 Lipos(11.2V) .... .... .... .... ....
5 Lipos(14V) ..... ..... ..... ..... .....
3. Rotation Reverse: Reverse motor rotation 5 short musical notes
4. Soft Start: Enable: 5 short musical notes
Disable: 5 long musical notes
5. Under Voltage:
Ignore: _.. _.. _.. _.. _..
Reduce Power: _. _. _. _. _.
Cut Off: ._ ._ ._ ._ ._
6. Timing:
Automatic (7 - 30 Degree) .. .. .. .. ..
Soft (7 degrees) .. .. .. .. .. .. .. .. .. ..
Hard(22 - 30 Degrees) .. .. .. , .. .. .. , .. .. .. , .. .. .. , .. .. ..
7. Frequency: 8kHz ' ' ' ' '
16kHz b b b b b
Restore Default Settings: _____ _____ _____ _____ _____
8. Active rpm control:
rpm control off: _._ _._ _._ _._ _._
20,000 rpm _.._ _.._ _.._ _.._ _.._
50,000 rpm _..._ _..._ _..._ _..._ _..._
100,000 rpm _...._ _...._ _...._ _...._ _...._
(60A/80A only)
Factory Default Settings:
Brake: Off Battery Type: 3 Li-Poly Under Voltage: Reduce Power Soft Start: Enable
Timing: Auto Frequency: 8kHz Active RPM Control: Off
Ale to chyba nie do niego. Słowa angielskie rozumiem i wiem o co chodzi ale dzwięki w ogóle nie pasują, np.
(drążek full)
1 lalala, pi; lalala, pi; lalala, pi; lalala, pi pi; lalala, pi pi; alala, pi pi; lalala pi pi pi; lalala pi pi pi; lalala pi pi pi; lalala pi pi pi pi; lalala pi pi pi pi; lalala pi pi pi pi; lalala pi pi pi pi pi; lalala pi pi pi pi pi; lalala pi pi pi pi pi; lalala pi pi pi pi pi pi; lalala pi pi pi pi pi pi; lalala pi pi pi pi pi pi. i znowu od nowa: lalala, pi....
I na przykład kiedy wezmę drążek do połowy kiedy będzie robił to robi się takie coś:
pi tuu; pi tuu; pi tuu; pi tuu tuu; pi tuu tuu; pi tuu tuu; pi tuu tuu tuu; pi tuu tuu tuu; pi tuu tuu tuu; pi tuu tuu tuu tuu; pi tuu tuu tuu tuu; pi tuu tuu tuu tuu; pi tuu tuu tuu tuu tuu; pi tuu tuu tuu tuu tuu, pi tuu tuu tuu tuu tuu, pi tuu tuu tuu tuu tuu tuu; pi tuu tuu tuu tuu tuu tuu; pi tuu tuu tuu tuu tuu tuu; pi tuu tuu tuu tuu tuu tuu tuu; pi tuu tuu tuu tuu tuu tuu tuu; pi tuu tuu tuu tuu tuu tuu tuu i znowu od nowa: pi tuu; pi tuu...
Ta instrukcja jest chyba do innego modelu...
  • 3 tygodnie później...
Zakupiłem taki sam regulator i mam wielki problem z programowaniem z radia. Wiele osób mimo posiadanej instrukcji ma z tym problem. Czy można ten regulator zaprogramować z karty i gdzie można ją dostać?
Insrukcja niby czytelna ale ja nie mam pojęcia co w danej chwili należy wykonać.
Proszę o pomoc
Ireneusz Kurka
Dostaniesz bez problemu - poszukaj tam gdzie regulator kupiles.
Jaki konkretnie problem masz ?
Ten regulator ma menu glowne i podmenu.
Najpierw czekasz az w glownym menu zapika Ci pozadana sekwencja - wtedy jak chcesz cos tam zmienic - to przesuwasz draga NA SRODEK - nastepnie pika kazda z kolejnych "podopcji wyboru" - w momencie kiedy zapika sekwencja odpowiadajaca pozadanym ustawieniom - przesuwasz drag NA MAX.
Trochę potestowałem i nadal kicha.
Czy ten regulator można zaprogramować z karty innego producenta?
Jak tak to jakiej i gdzie można ją kupić?
Sprzedawca mojego regulatora takich kart nie posiada.
Ireneusz Kurka
