wybor silnika
virtuss
Czym sie roznia te 2 silniki ? Ktory bedzie lepszym wyborem do akro 3D (okolo 1200g).
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=3884
TURNIGY AerodriveXp
Model: TR35-42-D
Input Voltage : 7.4V~14.8V (2~4S Li-po)
Kv : 1000 rpm/V within 10%
Max. efficiency current : 22~35A
Current capacity : 45A/30s
Dimentions : 35mm X 42mm / 1.38in X 1.65in
Shaft diameter : 4mm / 0.16in
Weight : 132g
Number of poles/magnets : 14
Recommended model weight : 1000~2300g / 35~81oz
Power equivalent : .30 to .35 IC glow engine
Stator Dimentions: 28x20mm
Suitable for the following model weights;
Trainer: up to 2.6kg
Warbird/Sport: 1.8kg
3D: 1.5kg
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=7125
Model: SK35-42 1000
Kv: 1000rpm/v
Turns: 5
Resistance: 48
Idle Current: 1.7A
Shaft: 4mm
Weight: 142g
Rated Power: 605w
ESC: 45A
Cell count: 3~4 Lipoly
Suggested Prop: 10*6, 11*5, 13*8
Power equivalent : .30 to .40 glow engine
bierz ten 2. Te silniki są niemalże takie same, ale ta seria SK jest trochę cięższa, ale lepiej wykonana. Przez co daje nam więcej mocy :D
