Porównanie serw - baza 202 modeli. Poleca P. Rondel ;)
cZyNo
przypadkiem znalazłem takie coś:
http://www.aeroglide.net/fichiers/no...rvormances.rar
trzeba wypakować i można porównywać. Uwaga - ma jedna wade - jest po francusku :D
a to co Mr Rondel napisałe o tym serwisie:
This is exactly what Servormances does !
You just need to download it, install it and run it. Less than 2 minutes overall ...
Most of the servos listed above are tested under the exact same protocol, so you can compare them directly.
The servormances team is totally independant, an they test servos that are kindly provided by the modellers, then returned as test are non destructives.
Cheers,
Pierre
  • 3 miesiące temu...
