Regulator WoW Rc 30/40 A
michcio88
musisz między piknięciami machać drążkiem gazu.
te regle są skomplikowane niestety, żeby do czegoś dojść, trzeba nawet akusa rozładować ;)
Poszukaj w sieci instrukcji programowania do tego regulatora. Albo w sklepie, gdzie kupowałeś, albo na zagranicznych forach. To jest to samo, co Tower Pro. Można go programować też za pomocą karty.
EDIT:
Spróbuj w poniższy sposób, może zadziała (przynajmniej podstawowe ustawienia):
Remove prop from motor if fitted
Connect speed controller to motor and receiver
Disconnect battery from speed controller
Move throttle stick on your transmitter to full throttle
Reconnect battery to speed controller
After three seconds you will hear sound patters (Each one repeated three times)
These sounds represent programmable functions-
= CELL Type and Number
== BRAKE
=== TIMING Mode
==== VOLTAGE protection
When you hear the sound pattern relating to the function you wish to programme move the throttle to the MIDDLE position
The ESC will then emit sounds again in groups of three in the following order-
+ NiMh/Nicad/Auto
++ 2 LiPo 7.4v
+++ 3 LiPo 11.1v
++++ 4 LiPo 14.8v
BRAKE
+ Off
++ Soft
+++ Medium
++++ Hard
TIMING
+ 2 degrees
++ 7 degrees
+++ 15 degrees
++++ 30 degrees
PROTECTION VOLTAGE
+ 2.8v/Cell
++ 2.9v/Cell
+++ 3.0v/Cell
NB: 10C and higher suggest 3.0v
When you hear the pattern sound for the function you require move the throttle to the UP position
A long BEEP will be heard confirming the option has been saved
The system will then revet back to the programming mode for the next option
When all functions have been selected move throttle to the DOWN position
The system will save all selections after one second and the unit will then be ready for use.
