Test kamer.
Peter
Czy kamera moze zaklocac ?
Nie trzeba czytac,wystarczy spojrzec na pomiary.
The noise the KX151 cams send back on the GND and +12V line
and on the Video line is alarming high.
ok it is understandable it contain huge amounts of noise in the 0-5MHz range,
due to coubling from the video line into the powerlines.
but check all those other spurs I found:
KX151 NTSC KPC-S700C
19.08MHz -62dBm
29.08MHz -76dBm
38.14MHz -55dBm
47.16MHz -80dBm
57.21MHz -62dBm
76.28MHz -63dBm
KX151 PAL KPC-S700CH hires
24.93MHz -70dBm
28.38MHz -47dBm
32.81MHz -70dBm
35.47MHz -80dBm
42.57Mhz -70dBm
56.75Mhz -46dBm
63.8MHz -81dBm
70.94MHz -60dBm
at all frequencies I have double checked the spur goes away when power to the CAM is taken off,
the signal power is simply measured directly over the cams power supply,
I used 20 cm wires to a lab DC supply.
Spectrum Analyzer HP E4402B is calibrated.
remember the receivers we use are not always double super converting,
so they are open (wide) so this is a potential cause of bad range when not isolated and not power supplied right,
be very carefull with the GND and power connections.
Good RC receivers have -110dB sensitivity
Bad RC receivers have -100 dB
if they are broken and have only -90dB you can only fly 200-300m away,
I have tested that !!
I have opened both of the above mentioned cameras and found:
the PAL version crystal oscilator is 28.3 Mhz
and its gnd caps share the same GND area as the video output driver
and the crystal is bended directly in over the video output amp,
and the crystal case is just left un grounded,
there is room for a tiny condenser mic, the onboard mic amp is mounted and connected, the 4th pis is the audio out.
The NTSC version is a bit better designed, the crystal osc does not share directly gnd with th video amp, and the crystal is bended in the other direction.
I suggest to the designers of the cams: add a low pass filter to the video output,
and better power supply filterings and case grounding,
yes the case is so much alive, so keep them cams away from your RX
and be care full with range checking before flying.
Czesciowo to wyjasnia zaklocenia w locie.Komentarz do tego zagadnienia bedzie zamieszczony w pozniejszym terminie.
