Jaki aktualnie dostępny silnik jest najbliższy parametrami speed 600 7,2V eco
SPEED 600 ECO 7,2 V Graupner 3323 Low-cost, current-saving versatile E-motor for a wide spectrum of applications. Suitable for electric powered model planes with 6–8 NiCad cells and a propeller of approx. 20 x 11 cm.
Nominal voltage 7,2 V
Operating voltage range 6 ... 9,6 V
No-load rpm 11000 min–1
No-load current drain 1 A
Current drain at max. efficiency 7,5 A
Current drain when stalled 50 A
Max. efficiency without gearbox 72 %
Length of case, excl. shaft 57 mm
Diameter 37 mm
Free shaft length 8,7 mm
Shaft diameter 3,17 mm
Weight 220 g
