witam wszsytkich moze ktos uzywa silnika e max cf2822 z pakietem 2 celowym 7,4 wolta, ile cigu mozna uzyskac czekam na odpowiedzi.
Podałem Ci już stronę do testów tego silnika. Tam jest napisane.
Recommended props when using 3 cell Lipo batteries:
The GWS EP9050 produces 30 ounces of thrust at 17 amps. Use with caution
The GWS EP8040 produces about 24 ounces of thrust at 12 amps. Best all around prop for this motor.
The APC 8x4E produces 25 ounces of thrust at 14 amps.
The GWS HD8060 produces 22 ounces of thrust at 17 amps. Use with caution
The GWS EP7035 produces 15 ounces of thrust at 7 amps.
The APC 7x6E produces 19 ounces of thrust at 12 amps.
Recommended props when using 2 cell Lipo batteries:
The GWS EP1170 prop produces about 21 ounces of thrust at 15 amps
The GWS EP1060 prop produces about 18 ounces of thrust at 12 amps.
The GWS EP1047 prop produces about 19 ounces of thrust at 13 amps.
The GWS EP9050 prop produces about 16 ounces of thrust at 10 amps.
The GWS EP8040 prop produces about 12 ounces of thrust at 6.5 amps.
1 oz=28gram
Wpisz w google "1 oz convert to grams" i bedziesz miał kalkulator.
Nie pytaj w każdym wątku o to samo. Poczekaj, na pewno ktoś odpowie.
