alenik Opublikowano 1 Sierpnia 2010 Opublikowano 1 Sierpnia 2010 Standardowo w gniezdzie SPC wpieta jest zworka. Zwierany jest pin srodkowy(minus) z pinem sygnalowym (??!?!, nie plusem ) Chce wykorzystac port SPC do monitorowania napiecia na pakiecie 3S. Wpinam sie w DIN`a przy pakiecie natomiast nie mam pewnosci jak wpiac sie w gniazdo SPC. W ktore piny mam wpiac plus i minus z pakietu??
alenik Opublikowano 2 Sierpnia 2010 Autor Opublikowano 2 Sierpnia 2010 Na stronie... http://www.rcgroups.com/forums/showpost.php?p=13666959&postcount=1416 Znalazlem odpowiedz .... .... 9. SPC port is polarised with the same slot, to accept "S" or "J" plugs, as all other ports. This enables immediate use of any other RX battery (or servo) lead. When using separate power supply for SPC - 1. Top pin = Left blank (Signal on the servo slots but not on SPC slot) 2. Middele pin = Positive 3. Bottom pin = Negative SPC blanking plug is a "J" style connector to ensure it cannot inserted incorrectly. Pins 1 & 2 are shorted (pin 3 must be left unconnected) which informs Optima to close 0-35V input section and draw power for it's own separate circuit requirement from the 0-7.4v servo power supply plugged into one or more of the other servo slots. SPC circuit when powered by separate battery or via a lead, (servo plug & lead will suffice), the top pin must be left blank. On EP Models, SPC lead may be simply connected to ESC battery connector terminals or in need remove a little insulation and solder direct to (+) & (-) wires a little behind ESC plug (Refer attached diagram) and insulate with self amalgamating tape or similar ....
smootny Opublikowano 2 Sierpnia 2010 Opublikowano 2 Sierpnia 2010 Na stronie... http://www.rcgroups.com/forums/showpost.php?p=13666959&postcount=1416 Znalazlem odpowiedz .... .... 9. SPC port is polarised with the same slot, to accept "S" or "J" plugs, as all other ports. This enables immediate use of any other RX battery (or servo) lead. When using separate power supply for SPC - 1. Top pin = Left blank (Signal on the servo slots but not on SPC slot) 2. Middele pin = Positive 3. Bottom pin = Negative SPC blanking plug is a "J" style connector to ensure it cannot inserted incorrectly. Pins 1 & 2 are shorted (pin 3 must be left unconnected) which informs Optima to close 0-35V input section and draw power for it's own separate circuit requirement from the 0-7.4v servo power supply plugged into one or more of the other servo slots. SPC circuit when powered by separate battery or via a lead, (servo plug & lead will suffice), the top pin must be left blank. On EP Models, SPC lead may be simply connected to ESC battery connector terminals or in need remove a little insulation and solder direct to (+) & (-) wires a little behind ESC plug (Refer attached diagram) and insulate with self amalgamating tape or similar .... Dokładnie tą samą informację znalazłem w internecie na innej stronie (niestety spóźniłem się, byłeś szybszy :] ) - trzeba będzie przetestować tą funkcję. Pozdrawiam - daj info czy się dało.
alenik Opublikowano 3 Sierpnia 2010 Autor Opublikowano 3 Sierpnia 2010 Ze wstepnej analizy... wychodzi na to ze sygnal ostrzegawczy uruchamia sie przy 5,5v Z tego co wyczytalem aby poziom ten zmienic niezbedne jest polaczenie z PC Wroce z urlopu, bede testowal a na chwile obecna informacja na wyswietlaczu o aktualnym napieciu odbiornika jest znacznie bardziej wiarogodna, wygodna itd... niz usredniony ze wczesniejszych lotow przyblizony, mozliwy czas latania w minutach *Edit: Aktualizacja oprogramowanie dla aurora daje mozliwosc zmiany ustawien przy których włącza się alarm ostrzegawczy bezpośrednio z poziomu ekranu dotykowego! Jeszcze nie przetestowane przezemnie!
Princes Opublikowano 9 Maja 2016 Opublikowano 9 Maja 2016 Witam Mam pytanie odnośnie tego tematu .Tez posiadam apkę aurorkę 9 i chcę aby monitorowanie na ekranie nadajnika było zgodne z napięciem pakietu w modelu.Problem w tym ,że aurora wskazuje tylko odczyt 5,2 v dlatego ,ze BEC nie puszcza wiecej prądu .Wiec jak to zmienić aby na wyświetlaczu pokazywał się aktualny stan pakietu w modelu ???
Bartek Piękoś Opublikowano 9 Maja 2016 Opublikowano 9 Maja 2016 Czytałeś instrukcyjkę od apki aurorki?(Grrrrr!) Napięcie musisz podać na odbiornik nie poprzez BEC, tylko bezpośrednio z pakietu. Masz to opisane i narysowane w instrukcji od APARATURY.
Princes Opublikowano 9 Maja 2016 Opublikowano 9 Maja 2016 Tak czytałem... ale tam bardzo lakonicznie i krótko jest to opisane więc mogłem nie ogarnąć tematu.Do tej pory używałem Optica 6 wiec pakiet był podłączony bezpośredni do kanału.Reasumując czyli gdzie mam podpiąć pakiet skoro idzie on przez Beca ( w reglu) ?? Jesli to jest to o co mi chodzi to juz wszystko rozumiem ..:-)
