Futaba 9 chp drugi kanał do gazu
Grzesiek
jedynieco siie da to wykorzystać 8 kanał  regulacja mieszanki na drugi silnik i zmiksować ustawiając 1:1 czyli prostą pod kątem 45 stopni:
THROTTLE-NEEDLE mixing (ACRO/HELI): THROTTLE-NEEDLE is a pre-programmed mix that automatically moves an in-flight mixture servo (CH8) in response to the THROTTLE STICK inputs for perfect engine tuning at all throttle settings. This function is particularly popular with contest pilots who fly in a large variety of locations, needing regular engine tuning adjustments, and requiring perfect engine response at all times and in all maneuvers. Also popular to minimize flooding at idle of inverted engine installations or installations with a high tank position. Not needed for fuel injection engines, which do this automatically. Adjustability: • Five-point curve allows adjustment of engine mixture at varied throttle settings. • The in-flight mixture servo must connect to receiver CH8. • In-flight mixture servo may also be used as a second servo for tuning a twin. • Throttle cut feature also moves the in flight needle servo. • The CH8 knob adjusts the high throttle mixture (may be deactivated. see AUX-CH). • Because both use CH8, this function cannot be used simultaneously with AILEVATOR. • An acceleration (ACCE) function (ACRO only) helps the engine compensate for sudden, large amounts of throttle input by making the mixture suddenly richer, then easing it back to the proper adjustment for that throttle setting. This function requires some adjustment to best fit your engine and your flying style. Adjust engine’s response until no hesitation occurs on rapid throttle input. • Separate curves are available (HELI only) for normal, idle-ups 1 and 2 combined, and idle-up 3. Immediately below THR-NEEDLE the radio displays the curve you are editing; ex: >NORML; and then which condition is currently active by your switches ex: (ID1/2). Note that you can edit the mix for a different condition without being in that condition, to allow editing without having to shut off the helicopter’s engine every time. Be sure you are editing the proper curve by checking the name after the > and not the one in parentheses. GOAL of EXAMPLE: STEPS: INPUTS: 58 Activate THROTTLE-NEEDLE mixing. Adjust the points as follows to resolve a slight lean midrange problem: 1: 40% 2: 45% 3: 65% 4: 55% 5: 40% Where next? Open the THROTTLE-NEEDLE function. Activate the function. HELI only. Select the condition to edit. Adjust the travels as needed to match your engine by slowly moving the stick to each of the 5 points, then adjusting the percentage at that point until the engine is properly tuned. ACRO only. Optional: increase mixture when throttle is applied rapidly-ACCE. (see above for details.) HELI only: set curves for other conditions. Close menu. for 1 second.(If basic, again.) to THROTTLE-NEEDLE. as needed. THROTTLE STICK. to 40%. until POINT 2 is highlighted. to 45%. to POINT 3. to 65%. to POINT 4. to 55%. to POINT 5. to 40% THROTTLE STICK to idle. THROTTLE STICK full open quickly. as needed. to condition name. to next condition to edit. Repeat above steps as needed. Se
  • Dzięki 1
Odnośnik do komentarza
Udostępnij na innych stronach
