Zefirek Opublikowano 31 Sierpnia 2012 Opublikowano 31 Sierpnia 2012 The Polish built Wilga is famed for it's STOL capability and ruggedness, two features that this great little scale model also shares!Manufactured from ultra-tough EPO foam, this Wilga is nicely molded with plenty of detail, assembly is fast, helped by the included brushless motor, servo's and ESC all being pre-installed. Considering it's price, this great looking Wilga is packed with features, including sprung main wheels and tail wheel, hinged side door with a latch for easy battery access, pre-fitted flaps and a scale prop that is secured by a practical O-ring saver.This Wilga is the perfect scale parkflyer, it's combination of a light flying weight and toughness make the Wilga easy to live with and it's slow fly capability, especially when using the pre-installed flaps is impressive, this is a brilliant model for a relaxing days flying!Features:Plug and Fly - Simply add your own RX and Battery! (not included)Tough Epo ConstructionHigh Level of Scale DetailEasy and Fast AssemblyFlaps Pre-Installed as StandardRemovable 1pc Wing for Easy TransportSprung Main Under-Carriage WheelsSprung, Steerable TailwheelMotor, Servo's and ESC Pre-InstalledO-Ring Prop Saver for ReliabilityIncludes:Manual2 x Scale PropSpecs: Material: EPOWingspan: 950mmLength: 678mm Flying Weight: 360gSpeed Controller: 15A brushless ESC w/BEC Servo: 1 x 8g and 3 x 6gMotor: 2226-2300kv Brushless Outrunner5 ChannelRequired:Your own 5~6 Channel Tx/Rx2s 7.4V 1000mAh Lipoly Battery
Filip. Opublikowano 31 Sierpnia 2012 Opublikowano 31 Sierpnia 2012 Nie doszła do nich jeszcze wiadomość, że mówi ( i pisze ) się u nas po polsku :
Wojtass_nt Opublikowano 31 Sierpnia 2012 Opublikowano 31 Sierpnia 2012 Projektant się chyba spieszył bo zapomniał kuknąć jak powinna wyglądać maska silnika. A ta co jest to nie wygląda ani jak ze starej wilgi ani jak z 2000 tylko jakieś wiadro.
kesto Opublikowano 31 Sierpnia 2012 Opublikowano 31 Sierpnia 2012 taki ładny samolot spieprzyć. Chyba nie lubię już żółtej rasy
karand Opublikowano 1 Września 2012 Opublikowano 1 Września 2012 Wilgi 2000 to ten model absolutnie nie przypomina. Zresztą, ...na bokach kadłuba ma napis "Wilga 35A" . Tylko w tytule opisu w HK widnieje to "2000".
ECO400 Opublikowano 7 Września 2012 Opublikowano 7 Września 2012 projekt skopany, to fakt, ale po dorobieniu własnej maski i zmianie napisów będzie z niej całkiem fajna popierdółka do polatania przed domem. półmakieta taka
robertus Opublikowano 8 Września 2012 Opublikowano 8 Września 2012 DOSAAF to coś jak Obrona Cywilna. Tylko samolot powinien byc żółto czerwony. Wtedy rosyjskie napisy bedą ok.
