Treść opublikowana przez Zefirek
Powitać szanownych kolegów
Zefirek odpowiedział(a) na JacekK temat w REGULAMIN FORUM oraz powitalnia
Witamy -
The Polish built Wilga is famed for it's STOL capability and ruggedness, two features that this great little scale model also shares! Manufactured from ultra-tough EPO foam, this Wilga is nicely molded with plenty of detail, assembly is fast, helped by the included brushless motor, servo's and ESC all being pre-installed. Considering it's price, this great looking Wilga is packed with features, including sprung main wheels and tail wheel, hinged side door with a latch for easy battery access, pre-fitted flaps and a scale prop that is secured by a practical O-ring saver. This Wilga is the perfect scale parkflyer, it's combination of a light flying weight and toughness make the Wilga easy to live with and it's slow fly capability, especially when using the pre-installed flaps is impressive, this is a brilliant model for a relaxing days flying! Features: Plug and Fly - Simply add your own RX and Battery! (not included) Tough Epo Construction High Level of Scale Detail Easy and Fast Assembly Flaps Pre-Installed as Standard Removable 1pc Wing for Easy Transport Sprung Main Under-Carriage Wheels Sprung, Steerable Tailwheel Motor, Servo's and ESC Pre-Installed O-Ring Prop Saver for Reliability Includes: Manual 2 x Scale Prop Specs: Material: EPO Wingspan: 950mm Length: 678mm Flying Weight: 360g Speed Controller: 15A brushless ESC w/BEC Servo: 1 x 8g and 3 x 6g Motor: 2226-2300kv Brushless Outrunner 5 Channel Required: Your own 5~6 Channel Tx/Rx 2s 7.4V 1000mAh Lipoly Battery
Pierwszy ślizg dla nowicjusza.Porady potrzebuję
Zefirek odpowiedział(a) na wicher123 temat w Statki , okręty, okręty podwodne , żaglowce
http://pfmrc.eu/index.php?/topic/29836-s-sprzedam-model-slizgu-klasy-eco-standard/ Pozdrawiam, Marcin -
Wciaganie dzioba lodzi pod wode.
Zefirek odpowiedział(a) na hornet20 temat w Statki , okręty, okręty podwodne , żaglowce
Ciężko będzie to rozpędzić Proponuje zmianę kadłuba ... http://pfmrc.eu/inde...y-eco-standard/ -
I decyzja zapadła ... będzie Wicherek 10 Model w stylu retro z silnikiem retro - OS PET 099 1,6 ccm z 1961 roku
Drążek gazu ustaw w maksymalnym wychyleniu. Podłącz zasilanie do regulatora. Po sygnale dzwiękowym, szybkim ruchem przesuń drążek w dół - usłyszysz kolejne sygnały dziękowe ... i to tyle, powinno działać. Pozdrawiam, Marcin
Mojego dremelka 4000 nigdy nie zamieniłbym na nic innego Czasem warto dopłacić więcej i cieszyć się ze sprzętu latami. Pozdrawiam, Marcin
Działa, dzięki.
Witam, Jak zmienić nazwę modelu w tej aparaturze? MENU>SYSTEM SETTING>MODE NAME Wchodzę, mam napis TURNIGY, wybieram pierwszą literę, czyli "T". Latam po afabecie na dole... i nic! Jak to zmienić? A może tak nie powinno być? Pozdrawiam, Marcin
Lakier akrylowy?
Przymierzam się do innej konstrukcji Tak też myślałem, jakieś przykłady lakieru nadającego się do tego celu? Czym zabezpieczyć piankę EPP przed paliwem? Pozdrawiam, Marcin
Czy paliwo rozpuszcza piankę EPP? Pozdrawiam, Marcin
Oj... czarno to widzę. Czekam na zdjęcia dokumentujące tą radosną twórczość.
Zdesperowany, udałem się do sklepu w poszukiwaniu odstraszacza. Najbardziej sensowny (zawartość deet/cena : 24%) wydał mi się BROS spray max. Dzisiaj przetestuje KOMAROM MÓWIMY... PRECZ! Pozdrawiam, Marcin
Dzisiaj, podczas latania zwątpiłem ... dopadła mnie chmara komarów. Latać się nie dało w takich warunkach, więc szybko zwinąłem sprzęt i udałem się do domu. Jak sobie radzicie z tym zjawiskiem? Pozdrawiam, Marcin
Myślałem raczej o jakimś "maluchu", powiedzmy 1,5 ccm (wydaje mi się, że silniki te często gasną na niskich obrotach). Według moich spostrzeżeń, sensowna regulacja zaczyna się od 3,5 ccm. Wynika to może z faktu, że wcześniej nie miałem styczności z silnikami o mniejszej pojemości. Najmniejsze jakich używałem, te o poj. 2,5 ccm miałem w modelach na uwięzi, ale tam wchodziły od razu na maksymalne obroty i nie było potrzeby ich regulacji. Te minusy właśnie sprawiają, że zastanawiam się nad budową takiego modelu... Zapach spalonej rycyny, a ten dzwięk pracującego silnika Silniki o większej pojemności same nie gasną bez przyczyny, nawet na niskich obrotach. Konieczność tankowania? Przecież wygodniej jest zatankować, niż czekać aż się naładuje akumulator. Wszelki sprzęt niezbędny do ekspolatacji posiadam. A jak było z jego niezawodnością? Gasł na niskich obrotach? Chciałbym uniknąć sytuacji, w której gaśnie mi silnik podczas lotu. Pozdrawiam, Marcin
Obecnie poglądy na wychowanie dzieci ulegają ciągłym przemianom. Szczególnie w czasach, gdzie zmiany we wszystkich dziedzinach życia zachodzą niezwykle dynamicznie. Media, takie jak: Internet, telewizja stanowią poważne zagrożenie dla rozwoju osobowości dziecka, a przecież każdy człowiek w dzieciństwie zaczyna odkrywać świat. Chłonie go wszystkimi zmysłami, dlatego też twórczość dla dziecka jest nie tylko źródłem przyjemności estetycznych, radości z własnej twórczości, ale przyczynia się do poznania otaczającego go świata. Dzieci rozwijając swoje umiejętności manualne, czerpią przy tym radość i zadowolenie, budując poczucie własnej wartości. Zajęcia takie, uspokajają je, dają uczucie odprężenia oraz zaspokaja typową dla tego wieku potrzebę działania. Dlatego wszelkie działania tego typu należy chwalić, a ludzi tworzących takie zaplecze dla rozwoju dzieci, wspierać w każdy możliwy sposób! BRAWO! Pozdrawiam, Marcin
Fakt, eter ciężko zdobyć.
Czasem bywam w okolicy. Faktycznie, masz rację. Regulacja obrotów przy silniku spalinowym o małej pojemności praktycznie nie istnieje. Pozdrawiam, Marcin
Zgadzam się w 100%. Nigdy nie miałem problemu z tym silnikiem, a wylatałem na nim kilka litrów paliwa w modelu na uwięzi. Też odpalałem go zawsze z palca Pozdrawiam, Marcin
Bixler, Pioneer, Easy Star lub podobny
Ja swoje przykleiłem na klej CA i nie ma takiej opcji aby się odkleiły. Szybciej pianka EPP ulegnie niż te połączenie
HD Wing Camera 1280x720p 30fps 5MP CMOS - $37.18 Specs: 120 degree wide-angle HD camera lens, 5 Megapixels COMS sensor Video resolution: 1280x720p 30fps Selectable video quality: Superior/Standard/economic Unique motion-detect recording function Selectable motion-detect recording time: 10sec, 1min, 5min, 10min Unique loop recording function Photo resolution: 2560x1920 JPG Built-in 850mAh Lipoly battery provides up to 3 hours of recording Vibration alert support (Vibrates to confirm functions) Memory slot: Transflash (Micro SD) support up to 32 GB Size: 74mm x 28mm x 15mm Weight: 29.4g PC camera function TV-OUT mode for Video play back and Funtion setup TV-OUT modes Supports PAL/NTSC USB2.0 Pozdrawiam, Marcin
ŁÓDKA dla początkującego.
Zefirek odpowiedział(a) na mariusz stasin temat w Statki , okręty, okręty podwodne , żaglowce
Koniecznie, już nie mogę się doczekać ... czekamy na zdjęcia przedstawiające relację z budowy. Pozwolę sobie na zamieszczenie grafiki z owej gry dla porównania efektu końcowego.
