Treść opublikowana przez komar1967
Tę stronę pewnie juz znasz... https://all3dp.com/1/20-must-creality-ender-3-upgrades-mods/
Potrzebna pomoc w zbindowaniu. Hitec Spectra, FrSky Minima 4ch
komar1967 odpowiedział(a) na Pit temat w Aparatury RC
Poniżej kawałek instrukcji do minimy. Moze to kwestia o której jest napisane w pt.2? Nadajnik powininien dzialać w modzie bez telemetrii. Powinna migać niebieska dioda. Linking the Receiver Receiver Receiver Receiver to your Transmitter Please note that this is only a general procedure. If in doubt, please also refer to your transmitter or module instructions. 1. Put your transmitter into link mode. Usually this is done by pressing the button on the transmitter module and turning on the transmitter. 2. Ensure that your transmitter is in non-telemetry receiver link mode. This can be done by looking on the transmitter module’s status light. If it is flashing Blue, it is in the correct mode. If it is flashing Red, you will need to change mode. To do this, press the button on the transmitter module for around 2 seconds. The status light should change between the two modes. If your module has old software, it may not be able to switch modes. 3. Press and hold the button on the receiver and then power up the receiver. 4. While the receiver is searching for the transmitter module, the Green light on the receiver will flash slowly. 5. Once the receiver is successfully linked to the transmitter module, the Green light on the receiver will flash rapidly. This should only take a couple of seconds and is usually instant. If in doubt, try increasing the distance from the transmitter modules antenna and the receiver. It is recommended to have the receiver between 50cm and 2m away from the transmitter when linking. -
Jest akurat w dobrej cenie (niecałe 650zł), z bezpłatną wysyłką z Czech. https://www.aliexpress.com/item/CREALITY-3D-Printer-Ender-3-DIY-Kit-3D-printer-Large-Size-I3-mini-Ender-3-V/32990122010.html?af=171752&aff_platform=aaf&cpt=1553066173261&afref=&cn=15643&dp=12%253A%253A171752%253A%253A0g004n6e3w9i%253A%253A%253A%253A1553066172&cv=12&pvid=339abf52-e80f-4989-938a-b2988f6e2a37&sk=Y7bAZbY&aff_trace_key=055ad58671584bfb8a4ed6eaf3fbf16b-1553066173261-06685-Y7bAZbY&rmsg=replace_same_item&scm=1007.23534.124000.0&terminal_id=fc1c1e3b13134968abeee097cab99fef
Phoenix Evo 2.6m by Sknera
komar1967 odpowiedział(a) na Sknera771 temat w Szybowce / motoszybowce piankowe
Ja mam wersje 2m. Na baterii 2200 3S spokojnie mogę latać kilkadziesiąt minut, ale zwykle mi się tyle nie chce, bo mnie boli kark Ten model, pisałem zresztą to wcześniej, uważam za wyjątkowo udany. Można nim latać zupełnie wariacko, łącznie z zaciąganiem na maksa steru wysokości w nurkowaniu. O dziwo skrzydła się nie składają, i nic mu się nie dzieje W zasadzie można nim robić w powietrzu dowolne numery. Aluminiową wręgę zrobił mi Kolega tokarz. Ona ma formę talerzyka, z dosyć cienką ścianką. Nie pamiętam w tej chwili, jakiego rozmiaru mam kołpak. -
Ja w swoim feniksie mam to zrobione tak jak na obrazkach. Od środka jest wręga laminatowa, na zewnątrz dorobiona aluminiowa z kołnierzem. -
Wybór motoszybowca? jako drugi model.
komar1967 odpowiedział(a) na afcht temat w Modele średniej wielkości
Będzie taki jaki założysz bo lepiej kupić KIT. Miejsca w kadłubie jest sporo więc zmieści się dowolny outruner o średnicy 35mm. Tu wybór jest duży. Niestety nie pamiętam co ja włożyłem. -
Ja polecę Volantex Phoenix 2000. Obecnie jest dostępna wersja druga tego modelu. https://www.rcgroups.com/forums/showthread.php?3107262-Volantex-Phoenix-V2-759-2-2000mm-Motor-Glider-build-log-review-mods Latam wersja pierwszą i model naprawdę daje radę. Kadłub jest zrobiony z bardzo odpornego tworzywa (chyba ABS) i trudno go ubić. Model jest naprawdę wytrzymały - w powietrzu można nim robić praktycznie dowolne numery i o dziwo skrzydła się nie składają i nic nie odpada Na klapach ląduje przy nodze. Polecam -
A gdzie można się czegoś więcej dowiedzieć o tym modelu?
Zdjęcie zamieszczone prze Grzegorza wygląda na leciwe, ale juz sam nie wiem, bo przed pilotem, jak nic, zamontowany jest na zgrabnym uchwyciku smatfon albo i inny GPS..
Dziś w Lidlu za 39,90 do wzięcia szybowiec
komar1967 odpowiedział(a) na czesio temat w Ciekawe oferty
Czy do LIDLolota wystarczą mikro-serwa 5g z uciągiem 0.8kg? Chcę zrobić sterowanie jaku u Jędrka, czyli całymi płatami skrzydła. -
A to nie przypadkiem wina narąbanego jak messerschmitt operatora kamery, który wywierał swoja obecnością niedopuszczalna presję na pilota?
Pioneer 1400 prośba o konsultacje {wychylenia sterów}
komar1967 odpowiedział(a) na Jarek67 temat w Modele średniej wielkości
https://abc-rc.pl/templates/images/files/995/1489664514-beta-1400-instrukcja.pdf strona 8 -
Podłączanie nadajnika i inne sprawy następujące.
komar1967 odpowiedział(a) na RemeR temat w Od czego zacząć??
Nie wiem czy tylko mi nie wyświetla się link do tego czegoś, z czym chcesz podłączyć ten odbiornik? Mogę się tylko domyslać, że chodzi o jakiś kontroler lotu. -
Jak płaciłeś Paypalem, to zgłoś roszczenie przez Paypal. Jest chyba na to 6 miesięcy od zakupu. Nie zmienia to faktu, że takie zachowanie sklepu to faktycznie przegięcie.
Chyba Kolega Dimmus nie był na lekcji jak przerabiano prawo Ohma.... Jeśli ta zabawka była zasilana 12V to spokojnie możesz dać 3 celowego lipola. Tylko prawdopodobnie powinieneś wymienić regulator na taki przystosowany do lipola, albo przynajmniej zastosować jakiś układ do monitorowania napięcia - w najprostszym wypadku wystarczy jakiś "bzyczek" do lipoli. W przeciwnym razie szybko wykończysz pakiet, bo lipole bardzo nie lubią być rozładowywane poniżej 3V/celę. W praktyce ustawia się jeszcze wyższy próg sygnalizacji.
Bindowanie odbiornika FSX6B z nadajnikiem FkySky I6 - jak?
komar1967 odpowiedział(a) na Speedaco temat w Odbiorniki RC
Pytasz o wyjścia PWM? Ja się z gotowym rozwiązaniem, które by tu podeszło, nie spotkałem - chyba trzeba rzeźbić samemu... Gdybyś chciał sterować serwami to można do tych wtyczek podkładać gotowe przewody zasilania i masy wyciągnięte np z przedłużaczy serw i później spiąć je razem i podlutować. Fabrycznie przewody są zaciskane w pinach - trzeba mieć zaciskarkę do tego. Można je też lutować i później podoginać kleszczykami, ale tu potrzebna jest wprawa, bo jak się to kiepsko zrobi, to później trudno je (piny z kabelkami) wsadzić do wtyczek. -
Jeśli chodzi o sygnały PWM to tylko z pierwszym kanałem masz komplet (+ - sig) wyprowadzeń. Pozostałe kanały są wyprowadzone tylko jako sygnał. Jak byś chciał sterować tym odbiornikiem np. serwa, to musisz do każdego serwa dostarczyć też zasilanie i masę. Natomiast do kontrolera lotu (jeśli byś chciał z jakiegoś powodu użyć sygnałów PWM) wystarczy to podpiąć tak jak jest. Natomiast oczywiście kontrolery lotu są zwykle przystosowane do sterowania PPM lub SBUS i wtedy nie podpinasz kabelków od PWM. Wg specyfikacji odbiornika na wyjściu PPM masz 8 kanałów a na SBUS -18. -
Ja do F3 stosowałem taki GPS w wersji z wtyczką OP ale on nie ma kompasu wbudowanego.
Ja również nie wspominam dobrze Gamy. Natomiast z czystym sumieniem mogę polecić Ci Fenixa 2000. W mojej ocenie bardzo udany model.
Ja czasami mam podobnie w moim FunCubie. Mam tam regulator EMAX ESC Simon 60A i też czasami po podłączeniu pakietu cisza i silnik nie kręci. Nie zaobserwowałem jakiejś prawidłowości kiedy tak się dzieje - mam kilka pakietów - ale chyba nie ma to chyba związku z pakietem. Czasami muszę kilkakrotnie podpinać i odpinać pakiet co by regiel "wystartował". Natomiast jak zapika to już zero problemów.
Doświadczenie pokazuje, że przy tak dużych paczkach szansa jest, ale malutka. Z EU idzie kurierem - paczkę będziesz miał - góra - za tydzień
Przykre. Nie wygląda najlepiej... Pewnie zreanimować się da, ale pierwotnej urody chyba nie odzyska. Vento niestety ma dosyć cienko pianki w okolicy kabinki. Nowy kadłub to koszt ok. 150zł - cały model (KIT) ok. 270zł
Jeśli to są pady przeznaczone do podpięcia właśnie kamerki i nadajnika fpv to podlutuj tak jak na rysunku. Nie wiem, jak jest w przypadku tej konkretnej płytki, ale czasami te napięcia do toru wideo są dodatkowo filtrowane. I jeszcze jedno- przyjęło się, że na forum zwracamy się do siebie na Ty. Pozdrawiam
Lądowaniem to bym tego nie nazwał... Model rozpadł się w powietrzu. Znasz przyczynę?
