Ładziak Opublikowano 2 Września 2008 Opublikowano 2 Września 2008 W tym temacie na RcGroups jest odpowiedź. Producent pisze, że ma się pojawić nowa wersja ładowarki oznaczona jako 106b+, m.in. z dodanym złaczem USB i większą mocą. Ma być również możliwe zupgradowanie 106b do nowej wersji (post nr #1678): I would like to say that the 106B+ is going to be released in the near future, and we will also do some program upgrading for 106B as before. Based on the previous 106B’s dimension and structure, the 106B+ (with USB port) is added more features and expanded power capacity. 1. Compared with the previous maximum charger power capacity 180W, the 106B+ is changed to 250W, which makes the current reach 10A even if the voltage is 25V. 2. Unique Lithium battery expanding discharge program. When you connect the external capacity resistance, you can use it as the maximum discharge power capacity—170W (@25V/7A). 3. Battery internal resistance measurement. The 106B+ can not only measure the internal resistance of the battery pack, and also can measure the per-cell internal resistance (only available for lithium battery). 4. Support upgrading the hardware program by USB port. The 106B+ also support the “Open Format” data of the “logview” software as communication port and can display, plot, analyze the charge and discharge data by it. See detail information about “logview “ in the following website: http://www.logview.info The following lists are 106B+ main specifications: Input voltage range: 10.0 – 18.0VDC Charge current range: 0.05 – 10.0A Discharge current range: 0.05 – 7.0A Maximum charge power capacity: 250W @ input voltage > 13.5V Maximum discharge power capacity: 20W Maximum extern discharge power capacity: 170W @ 25V/7A Current drain for balancing: <300mA Balance accuracy: <10mV Lithium (LiPo/LiIo/LiFe) battery cell count: 1 – 6 series NiCd/NiMH battery cell count: 1 – 17 series Pb battery cell count: 1 – 12 series (2 – 24V) Battery setup memories: 10 Intelligent temperature control: Yes PC Connect: USB port Weight: 350g Dimensions(L X W X D) : 134X83X25mm 5.28”X3.27”X0.98” Jeżeli cena niebędzie znacząco odbiegała od obecnej, to może być hicior
meteor Opublikowano 2 Września 2008 Opublikowano 2 Września 2008 meteor, u Ciebie co się stało? formowałem akku, i po drugim cyklu sie zrobiła strasznie ciepła, tak samo jak akku żelowy 12V 7Ah, wiec odłączyłem po ponownym włączeniu tylko piszczy i krzaki na górnej linii wyświetlacza :/
diem Opublikowano 2 Września 2008 Opublikowano 2 Września 2008 Gdyby kogos interesowalo - wysylka EMS Date # Location Delivery Status 25-Aug-2008 Hong Kong Item posted and is being processed. 26-Aug-2008 Hong Kong Processed for departure. 26-Aug-2008 Hong Kong The item left Hong Kong for its destination on 26-Aug-2008 27-Aug-2008 Poland Arrived and is being processed. 2-Sep-2008 Poland Unsuccessful delivery. Przesylka dotarla 2go wbrew tego co pisze. pozdrawiam
fredzio Opublikowano 3 Września 2008 Opublikowano 3 Września 2008 Wprowadzając nowy wątek do rozmowy o sklepie podzielę się ostatnimi spostrzeżeniami. Nie wiem ilu z was zauważyła wprowadzone niedawno do sprzedaży serwa cyfrowe. Przyglądając się ich parametrom ze zdziwieniem zauważyłem, że podano w ich parametrach napięcie zasilania 7,2V. Nie chcąc uwierzyć w to co widzę pogrzebałem trochę i dość ciekawą rzecz odkryłem. Otóż serwa te są serwami produkowanymi przez firmę Power HD i ich parametry są często znacząco odmienne od prezentowanych na stronie hobycity(na korzyść serwa). Pościągałem specyfikację poszczególnych serw i okazało się, że faktycznie większość obsługuje 7,2V oraz większość jest znacznie silniejsza niż wskazywałyby dane na stronie sklepu. Wierząc opiniom wyczytanym na RCG mój znajomy zakupił 6sztuk takich serw do swojej katany 2m. Jestem bardzo ciekaw wyników testowania tych serw. EDIT. Dodałem linka, który miał tam być edit qpa a ja go poprawiłem żeby działał
gfilipek Opublikowano 3 Września 2008 Opublikowano 3 Września 2008 Jestem bardzo ciekaw wyników testowania tych serw. Tu by się przydał link do serwa o którym piszesz Poproszę jeśli można....
n6210 Opublikowano 3 Września 2008 Opublikowano 3 Września 2008 Tak jakby link jest podany... kryje sie pod wyrazem "takich" http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6336
Tomek Opublikowano 3 Września 2008 Autor Opublikowano 3 Września 2008 Po tym co ostatnio się tu wydarzyło temat zamykam. Każdy o sklepie opnie sobie wyrobił , zaś do szukania dziury w całym , to może na innych forach sobie pogadajcie . Każdy wie o co mi chodzi , a jak nie, to tym lepiej , nie ma czym się chwalić. :oops: Jeszcze nie zastanowiłem się co zrobić z trzema muszkieterami walczącymi z polskim prawem. Na razie pokasowałem ich wypowiedzi ,aby nie narobili bigosu sobie jak i forum. :twisted: Podziękowania dla tych kolegów co zatrzymali choć trochę tych szaleńców. :* Zaś na przyszłość wszystkie tematy dotyczące różnych "sposobów" na przesyłki z zagranicy będę kasował od reki w całości , zaś ich autorów czeka ban.
