mjs
    3
Treść opublikowana przez mjs
  1. Wygląda jakby nie wychodziła z wody do ślizgu, może za krótki kadłub.
  2. A, jakby tak sztag zaczepić do dziobu?
  3. To prawdziwie wiosenna wiadomość! Brawo, ładnie wygląda.
  4. https://pl.aliexpress.com/item/80mm-TI-coated-Mini-HSS-Circular-Saw-Blade-Rotary-Cutter-For-Metal-Hand-Tool-Set/32738164250.html https://pl.aliexpress.com/item/5pcs-lot-80-teeth-TCT-blades-for-electric-mini-circular-saw-accessories-for-Multi-Function-electric/32606107255.html https://pl.aliexpress.com/item/7-pieces-HSS-saw-blades-for-dremel-ratory-tools-dremel-tools-dremel-accessories/32522072154.html?spm=a2g17.search0104.3.157.4d9a7372X2X2BV&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_5711211_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_5722412_10620_5711311-10621,searchweb201603_1,ppcSwitch_5&algo_expid=30765a55-65c6-4bbe-88e5-cc9fa3a537e8-23&algo_pvid=30765a55-65c6-4bbe-88e5-cc9fa3a537e8&transAbTest=ae803_3&priceBeautifyAB=0 https://pl.aliexpress.com/item/5pcs-High-Quality-saw-blades-for-dremel-ratory-tools-dremel-Abrasive-tools-dremel-accessories-1-mandrel/32532887902.html?spm=a2g17.search0104.3.164.4d9a7372X2X2BV&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_5711211_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_5722412_10620_5711311,searchweb201603_1,ppcSwitch_5&algo_expid=30765a55-65c6-4bbe-88e5-cc9fa3a537e8-24&algo_pvid=30765a55-65c6-4bbe-88e5-cc9fa3a537e8&transAbTest=ae803_3&priceBeautifyAB=0 https://pl.aliexpress.com/item/HILDA-Mini-Zestaw-5-PC-x-22mm-Ci-cia-Ostrza-Pi-y-Tarczowej-p-yta-Obrotowa/32847297046.html?spm=a2g17.search0104.3.171.4d9a7372X2X2BV&ws_ab_test=searchweb0_0%2Csearchweb201602_5_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_5711211_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_5722412_10620_5711311%2Csearchweb201603_1%2CppcSwitch_5&algo_expid=30765a55-65c6-4bbe-88e5-cc9fa3a537e8-25&algo_pvid=30765a55-65c6-4bbe-88e5-cc9fa3a537e8&transAbTest=ae803_3&priceBeautifyAB=0 https://www.leroymerlin.pl/elektronarzedzia/akcesoria-do-elektronarzedzi/tarcze-do-pilarek/tarcza-do-pilarki-tarczowej-b-hss-89-mm-zeby-80-szt-dexter,p381197,l503.html https://pl.aliexpress.com/item/7pcs-Mini-HSS-Circular-Saw-Blade-Rotary-Tool-For-Dremel-Metal-Cutter-Power-Tool-Set-Wood/32782425330.html?spm=a2g17.search0104.3.29.3fc06746afAEYn&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_5711211_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_5722412_10620_5711311-normal#cfs,searchweb201603_1,ppcSwitch_5&algo_expid=7f7aba81-ce3e-4d5d-8f29-3d2123c346d9-4&algo_pvid=7f7aba81-ce3e-4d5d-8f29-3d2123c346d9&transAbTest=ae803_3&priceBeautifyAB=0 https://pl.aliexpress.com/item/5pcs-lot-80-teeth-TCT-blades-for-electric-mini-circular-saw-accessories-for-Multi-Function-electric/32606107255.html?spm=a2g17.search0104.3.36.3fc06746afAEYn&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_5711211_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_5722412_10620_5711311-normal#cfs,searchweb201603_1,ppcSwitch_5&algo_expid=7f7aba81-ce3e-4d5d-8f29-3d2123c346d9-5&algo_pvid=7f7aba81-ce3e-4d5d-8f29-3d2123c346d9&transAbTest=ae803_3&priceBeautifyAB=0 https://pl.aliexpress.com/item/Circular-Saw-Blades-HSS-TCT-woodworking-Rotary-Tool-Cutting-Discs-Mandrel-for-mini-circular-saw-3pcs/1000004194140.html?spm=a2g17.search0104.3.130.3fc06746afAEYn&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10301_5711211_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_5722412_10620_5711311,searchweb201603_1,ppcSwitch_5&algo_expid=7f7aba81-ce3e-4d5d-8f29-3d2123c346d9-18&algo_pvid=7f7aba81-ce3e-4d5d-8f29-3d2123c346d9&transAbTest=ae803_3&priceBeautifyAB=0 https://abc-rc.pl/pila-tarczowa-do-drewna-50mm
  5. Jako technolog drewna powiadam - nie nadaje się. Na pokład powinna być sklejka lekka (cienka 1 mm) i sztywna. Niewielki łuk pokładu (1/24 szerokości) ułoży się spokojnie w sklejce modelarskiej, zwykłej, brzozowej, lotniczej, szkutniczej. Ale nie elastycznej i do tego o grubości 3 mm. Poza tym... jaka kasa za dostawę 1 arkusza???!!!??? Jeśli arkusz na cały pokład, to tutaj: https://centrum.meble.pl/p796055,sklejka-1-mm-1270x1270-wodoodporna-11-brzoza-modelarska.html (spójrz na koszt wysyłki), i na opcję pocięcia na formatki; albo w każdym dobrym sklepie modelarskim np. https://www.ef3m.pl/pl/p/Sklejka-modelarska-finska-1mm-x-310mm-x-1000mm/1677 http://sklep.modelarnia.pl/p5834,sklejka-modelarska-1-mm-250-x-630.html czy na Allegro: http://allegro.pl/sklejka-lotnicza-modelarska-brzozowa-1000x310-1mm-i5008499494.html http://allegro.pl/sklejka-modelarska-lotnicza-brzoza-250x630-1-2mm-i5160060077.html?reco_id=2ec9daf6-1cbc-11e8-8110-246e96849ee0
  6. Bardzo mały, mieści się na A4?
  7. Ech, brakuje tylko filmu cotygodniowego, jak u A. Słodowego albo J. Kubicy.
  8. Można, ale dla spokojności oblaminuj ją cienką tkaniną szklaną. Wtedy masz kompozyt. Wicherek swobodnie latający!
  9. Takie toto wpadło mi dzisiaj w oko, może się komuś przyda. Prosta, szybka konstrukcja. http://www.tbm.lasowice.net/toto000a.html
  10. Tu coś jest: https://www.mojehobby.pl/products/SZD-32-Foka-5.html#gallery_start Opis, wymiary: http://tetas.w.interiowo.pl/Zakatek/hangar/Foka5/hszd32.html Tu coś widać: http://www.beaufortgc.org.au/images/VH-GZD.gif A tutaj SZD-24: https://www.the-blueprints.com/blueprints-depot/modernplanes/modern-su-sz/szd-24-foka.gif (może podobny). I tam trochę konstrukcji: http://www.samolotypolskie.pl/samoloty/2863/126/SZD-24-Foka2 I jeszcze taka Foka '1966: https://outerzone.co.uk/images/_thumbs/plans/6922.jpg PTL historia: http://www.smil.org.pl/ptl/wyklady/32_Szybowce_Foka_i_Cobra.pdf Szału nie ma.
  11. Rysunki są tutaj: http://www.alehar.aplus.pl/plany.html
  12. Instrukcja obsługi:
  13. A jaka gramatura filii?
  14. Tu jest Wicherek piankowy, Prząśniczka a nawet Mustang: http://gammodel.pl
  15. Robiąc Optypesymista, chwilami myślałem o modelu zanętowym... http://pfmrc.eu/index.php/topic/71588-optypesymist-rc/?do=findComment&comment=693421 Formę na kadłub mam, jakby kto potrzebował skorupę, a może i sam spróbuję przeobrazić go w sprzęt wędkarski. Zwłaszcza, że ostatnio zauważyłem dość interesujący silnik z ośką 5 mm: http://www.rcskorpion.pl/towar/1-4491-silnik-szczotkowy-power-75540-robbe/, jak i mocny pakiet zasilania: http://allegro.pl/lipo-turnigy-5000mah-14-8v-4s-20-30c-hardcase-pack-i7111397783.html?reco_id=af69b04d-085d-11e8-a66e-246e9680b6a8&bi_c=Product&bi_s=archiwum_allegro&bi_m=reco#thumb/2.
  16. A nie lepiej na początek kupić gotowy wał? https://modelemax.pl/pl/waly-napedowe/19991-adm--wal-napedowy-m3-350-290mm.html
  17. http://www.profili2.com/eng/plans.asp
  18. Ten mikser ręczny z czubka świerka, to się nazywa fyrlejka.
  19. Jakby kto potrzebował sklejkowy kadłub 125 cm, to mam do zagospodarowania.
  20. A, nie zapomnij naoliwić wał przed jazdą. Jak wynika ze ściągi http://rc.susco.pl/p/235/8858/silnik-szczotkowy-mabuchi-550-pf-6v-12v-inni-producenci-silniki-szczotkowe-akcesoria.html, silnik pobiera 15 A czyli w ciągu 1 godziny potrzebuje energii = 15 Ah. Dzieląc to przez 12 otrzymujesz 1,25 Ah na 5 minut jazdy, co przekłada się na oznaczenie pojemności akumulatorka = 1250 mAh. Jeden z tańszych pakietów https://www.gimmik.net/3000mAh_111V_15C_3S1P_Gens_Ace,o,21057.html?gclid=EAIaIQobChMIiPaKguvy2AIVEYGyCh1KVgZUEAQYASABEgI3KvD_BwE pozwoli Ci na zabawę przez ok. 12 minut. A później ładowarka https://mdron.pl/1706,ladowarka-gpx-v3-do-lipo-life-2s-3s-z-balancerem.html?gclid=EAIaIQobChMIiPaKguvy2AIVEYGyCh1KVgZUEAQYBSABEgLgNvD_BwE i na wodę.
  21. Czy to nie ten sam kadłub? https://www.olx.pl/oferta/kadlub-modelarski-lodzi-CID767-IDh6ZhR.html#03d8f71e0b
  22. We FreeShipie możesz przechylić kadłub o dowolny kąt, zmienić zanurzenie i odczytać obliczenia choćby samej wyporności. No i poobracać go dookoła.
  23. mjs
    Lockheed 14 [Hudson] w 3D
    Mnie to wygląda na zawiasy łamane, których celem jest najpierw wypchnięcie drzwi na zewnątrz, a dopiero potem uchylanie. No bo krawędź przyzawiasowa idzie po łuku wypukłym.
  24. "Bardzo chciałbym zrobić w miarę poprawnie ten model, bo może to będzie ten ostatni?... Czekam na wasze wpisy. :)" - A, żeby nie był to model ostatni, a pierwszy z tych dużych i zacnych, to warto spróbować zrobić taki trik: 1. Wydrukować poniższy obrazek na A5. https://www.monitor-polski.pl/wp-content/uploads/2017/11/NanoWater-Bottle-Mockup-Horz-600-mln-bovisow.png 2. Postawić na nim szklankę z wodą. 3. Po 20 min. pojawiają się bąbelki na ściankach i dnie. 4. Popijać na zdrowie po 1/5 szklanki na dzień przez pierwszy tydzień, później 2/5 przez drugi itd. aż do pełnej szklanicy i do woli ile kto pragnie. Organizm pobiera i tak tyle ile potrzebuje nanoenergi uzdrawiającej, wzmacniającej i... odmładzającej. Po miesiącu, a piszę to z autopsji, siwy włos na głowie... ciemnieje. I modele chce się budować. I ja posklejałem kiedyś takiego dwupłatowca z Małego Modelarza, który z dumą stał na biblioteczce i budził respekt wśród kolegów. Później miałem okazje zobaczyć prawdziwego Polikarpowa na lotnisku Przylep k. Zielonej Góry, gdzie kuzyn Marek latał szybowcem i znad lasku podchodził do lądowania. Niezapomniany widok i świst szybowca, podziwiany z cienia skrzydeł "Kukuruźnika" (było lato, wakacje i upał, na niebie kumulusy). A na lotnisko jechaliśmy kolarzówką. https://scontent-waw1-1.xx.fbcdn.net/v/t1.0-9/13179233_690464461091939_3081654656270095244_n.jpg?oh=f44cbe43a402bababb33aadeca830f25&oe=5AE45170 Ciekawy film z wyprawy dwupłatem do Grecji: Powodzenia!
