Przysiadł raz na gałęzi mały wróbelek obok wielkiego orła, i patrząc na niego z wielkim podziwem pyta: - A kto Ty jesteś? - Ja jestem Orzeł, a Ty? - Ja też jestem Orzeł, tylko chorowałem.. Czytanie prasy też bywa przyjemne...
Saturn V launch vehicle computer Saturn V rocket launch animation. https://s3-us-west-1.amazonaws.com/hmt-forum/saturnv_animated_tanks.mp4 Colorized photograph of Dr. Wernher von Braun standing by the engines of his brainchild, the Saturn V super heavy-lift launch vehicle. The Von Braun Ferry Rocket was a concept design for a shuttle spacecraft developed by Wernher von Braun in the early 1950s. NASA Apollo contour rocket nozzle being tested in a test chamber that could simulate conditions found at very high altitudes, c. 1964. NASA water deluge rocket launch system. Several hundred thousand gallons of water are used to prevent damage from the extreme temperature and sound from a rocket launch. The water protects the new SLS rocket, Orion spacecraft, Mobile Launcher, and that one guy who took the Viral hot pepper challenge too far. https://s3-us-west-1.amazonaws.com/hmt-forum/nasa_water_deluge_system.mp4 https://s3-us-west-1.amazonaws.com/hmt-forum/nasa_rocket_test_stand.mp4 Machining a space shuttle main injector in 1977. Apollo service module fuel cell. Three cells were used to generate power for the spacecraft and water for the astronauts. NASA's Kilopower Reactor Using Stirling Technology (KRUSTY) prototype fission reactor for space travel. The reactor uses uranium-235 to generate heat that is carried to the Stirling converters with passive sodium heat pipes. https://www.nasa.gov/directorates/spacetech/kilopower a' propos.. Starting a nuclear reactor. The blue glow emitted by the reactor is the Cherenkov radiation. Named after named Soviet scientist and Nobel Prize winner Pavel Cherenkov, the electromagnetic radiation is emitted when a charged particle (such as an electron) moves through a dielectric medium faster than the phase velocity of light in that medium. https://www.nuclear-power.net/nuclear-power/reactor-physics/atomic-nuclear-physics/fundamental-particles/beta-particle/cherenkov-radiation/ https://s3-us-west-1.amazonaws.com/hmt-forum/reactor_startup.mp4 Space shuttle thermal tile material held in hand after 1 hour in a 2200° oven!! https://s3-us-west-1.amazonaws.com/hmt-forum/space_shuttle_thermal_tile.mp4 Obecnie... NASA CRS-18 vertical landing. https://s3-us-west-1.amazonaws.com/hmt-forum/nasa_crs18_landing.mp4 https://s3-us-west-1.amazonaws.com/hmt-forum/falcon9_booster_landing.mp4 https://s3-us-west-1.amazonaws.com/hmt-forum/spacex_assembling_heavy_falcon.mp4 SpaceX foundry casting Raptor engine manifold out of Inconel https://en.wikipedia.org/wiki/Inconel https://s3-us-west-1.amazonaws.com/hmt-forum/spacex_inconel_casting.mp4 Astra Rocket Engine in Inconel .......................................................................... WWII Tiny Tim air-to-surface rocket test. https://s3-us-west-1.amazonaws.com/hmt-forum/tiny_tim_air_to_surface_rocket_test.mp4 - Z drogi śledzie, bo król jedzie !.... Upps... :mrgreen: https://s3-us-west-1.amazonaws.com/hmt-forum/rocket_falls_off_of_landing_plane.mp4 Mobile rocket-assisted takeoff launch platform. Ostre hamowanie
Tego Ukrainie potrzeba na rosyjskie drony... https://s3-us-west-1.amazonaws.com/hmt-forum/laser_tree_trimmer.mp4
Sądzę, że przesuwa się nie w czasie kiedy pracuje jako frezarka, tylko po odchyleniu płyty silnika na dół na tym właśnie wałku do innych czynności..
Na pewno stolik do frezarki dolnowrzecionowej jak napisał kolega Piotrek, ale jako przystawka do większego kombajnu (jak nasza DYMA) mógł służyć jeszcze do napędu innych narzędzi, stąd ten zawias z ogranicznikami przesuwu płyty silnika, którego można ustawić również poziomo. Tak myślę...
To co napisał kolega Adam byłoby najlepszą opcją, gwarantującą poprawność wykonania roboty. Ale jeśli kolega zdecyduje to zrobić samemu.... Najpierw należy zmierzyć ile tego ubytku mamy, bo może się okazać, że to niekoniecznie potrzebne. Przedstawię dlaczego. Co do samego ubytku. Moim zdaniem jeśli czujnik pokaże kilka setek(1~10) to nie warto podejmować takiego wysiłku z co najmniej 2 powodów. • Pierwszy to pytanie: o ile obniży się wierzchołek noża tokarskiego kiedy sanie suportu najadą na zużyty fragment pryzm łoża? Można to zmierzyć bezpośrednio mocując w uchwycie dość długi, równy, najlepiej szlifowany wałek/trzpień, a czujnik na suporcie lub w imaku tokarskim w ten sposób by dotykał wałka jak w pozycji (b) od góry (czasem lepiej zastosować diatest kładąc poziomo na trzpieniu jego dźwigienkę, co eliminuje wpływ krzywizny na punkt styku z kulką czujnika). Zbliżając się do uchwytu czujnik powinien pokazać coraz większy uchyb. Ale sanie suportu są dość długie, i dociskane ciężarem do dalszej niewyrobionej części pryzmy mogą "wisieć" nad wyrobieniem na samym początku, lekkie dociśnięcie może ujawnić ten uchyb jeśli będzie znaczny. Pewniej będzie dokonać bezpośredniego pomiaru wytarcia za pomocą czujnika zamontowanego na koniku w sposób jak na zdjęciu - wykręcony z podstawy statyw czujnika zamocowany w uchwycie wiertarskim włożonym w tuleje konika (drugą opcją jest przyczepienie kostki magnetycznej statywu czujnika do wysuniętej i zaciśniętej w korpusie tulei konika, wybieramy opcję bardziej sztywną i stabilną bo będzie to rzutowało na rzetelność pomiaru). Czujnik przystawiamy prostopadle do powierzchni pryzmy. Konik jeździ po dużo zazwyczaj mniej lub wcale zużytych prowadnicach, wiec wpływ jego prowadzenia na wynik pomiaru będzie znikomy. Załóżmy, że zmierzony uchyb ma 0,05mm., w rzeczywistości obniżenie suportu i wierzchołka noża w osi pionowej będzie dużo mniejsze bo mierzona powierzchnia jest pod kątem 30°-45° do pionu (pryzmy zazwyczaj mają kąt wierzchołkowy 60° lub 90°). I wtedy mamy stosunek g (czyli nasz zmierzony uchyb 0,05mm) do h (faktyczne obniżenie wysokości w pionie) jak to pokazuje rysunek poniżej. (rysunek stworzony był do innego celu - obliczania ew. podkładki, ale zasada ta sama) Wartość liczbową wysokości h (przyprostokatna a) można wyliczyć z równań Pitagorasa trójkąta prostokątnego a=cos(beta)*c gdzie g to przeciwprostokątna c). https://pl.numberempire.com/right_triangle_calculator.php Jak widać już naocznie stosunek g do h jest ~5/4 • Drugi powód: jak przełoży się to na miejscowa zmianę średnicy toczonego detalu? Pokazuje rysunek niżej, i znów przyrost średnicy ⌀ toczonego detalu w stosunku do wysokości obniżenia wysokości wierzchołka noża ma się jak (Δr )do (Δh), Jak widać z powyższego przyrost średnicy ⌀ będzie mniejszy niż wysokość obniżenia Δh wierzchołka noża, poza tym im większa będzie toczona średnica ⌀, tym wpływ wysokości noża na nią będzie proporcjonalnie malał. Można to obliczyć analogicznie wzorami Pitagorasa podstawiając konkretne dane, przy czym kąt przeciwprostokątny (α) zależny będzie od promienia r1 (średnicy ⌀) toczonego detalu, oraz wysokości obniżenia noża Δh. Podstawiając promień r1 jako bok b, a wysokość obniżenia noża Δh jako bok a trójkąta prostokątnego, otrzymamy przyrost promienia Δr równy obliczonemu bokowi c od którego odejmujemy bok b (Δr=c-b). przyjmując, że toczymy średnicę ⌀30mm, Δh=a=0,04330mm, r1=b=15mm, https://pl.numberempire.com/right_triangle_calculator.php to Δr (przy kącie α =0,165°) wyniesie: c = 15.00006mm - 15,00mm = 0,00006mm czyli średnica wzrośnie o 0,00012mm ** - (jeśli znajdziecie koledzy gdzieś błąd to proszę mnie poprawić) 0rzy średnicy 6mm = Δr 0.00031mm przy kącie α=0.83° Reasumując - opłaca się taki uchyb poprawiać? Mocowanie i pomiar pryzmy pokazany jest na filmie. Jeśli czujnik nie sięga zza suportu, to konik można przełożyć przed suport, by można było dojechać czujnikiem do wrzeciennika (popychając go suportem zamiast ciągnąc jak na filmie). Jeszcze jedna uwaga, w gro przypadków mierzenie wierzchołka pryzmy(płaska część) nie wskaże wytarcia gdyż wrąb płyty suportu jej nie dotyka - wycierają się powierzchnie skośne. (takie wytarcie to już trzeba szlifować https://www.cnc.info.pl/tokarka-arad-sn400-1000-czy-jest-cos-warta-t113350.html ) Jeśli dalej interesuje kolegów przeszlifowanie to bedę kontynuował temat.
Szlifowanie pryzm łoża nawet w tak małej tokareczce to nie jest prosta sprawa, przy braku odpowiednich narzędzi i należytej staranności można więcej popsuć niż naprawić. No, ale w ogóle jest to wykonalne w amatorskich warunkach, tyle, że będzie wymagało przygotowania sobie właściwych narzędzi do wykonania, oraz pomiarów kontrolnych. Czujnik na statywie(najlepiej magnetycznym) jest niezbędny. Przesuwając konik z zamocowanym na nim czujnikiem magnetycznym(do zaciśniętej tulei lub do korpusu) możemy zmierzyć stopień zużycia pryzmy suportu. Praktyczne amatorskie metody szlifowania są dwie: - z wykorzystaniem zewnętrznych prowadnic głowicy szlifującej (jaka by nie była), jak to widać na filmie, Ale wymaga precyzyjnego ustawienia tychże prowadnic względem pryzm łoża, co wymaga długich przygotowań, pomiarów et cetera. - metoda druga, prostsza i bardziej realna do wykonania w amatorskich warunkach - szlifowanie z wykorzystaniem pryzm konika do prowadzenia narzędzia (a także dolnej części jego korpusu) które są zazwyczaj dużo mniej lub wcale zużyte niż prowadnice suportu.. W tej metodzie do prowadzenia głowicy szlifierskiej wykorzystuje się jako sanek dolej części konika która ślizga się po swojej pryzmie, równoległej do pryzmy obrabianej. Na sankach konika mocuje się kątownik, do niego obrotnicę z sankami narzędziowymi, do których zamiast imaka mocujemy szlifierkę. O co chodzi wyjaśnia zdjęcie poniżej. (tu akurat mamy sytuacje odwrotną - obrotnica zamontowana jest do suportu bo szlifowana jest pryzma konika) Sanki narzędziowe obrotnicy pozwalają precyzyjnie ustawiać głębokość szlifowania, a zamocowana obrotowo na kątowniku obrotnica ustawić właściwy kąt ściernicy względem szlifowanej pryzmy. zalecam szlifować pryzmę czołem ściernicy doniczkowej lub garnkowej jak na zdjęciu wyżej, wtedy profil i zużycie ściernicy nie mają wpływu na kształt uzyskanej powierzchni. (dokończę temat później bo już późno)
A zimówki założył...? https://s3-us-west-1.amazonaws.com/hmt-forum/landing_a_plane_into_a_runway_snowbank.mp4 Nie masz kółka przedniego? Ląduj na koziołku...
Na pewno kilkadziesiąt? orlen https://www.orlen.pl/pl/dla-ciebie/stacje?kw=&from=&to=&s=1669&wp=&dst=0 https://elektromobilni.pl/mapa-stacji-ladowania/ a żeby było się z czego pośmiać...
Ja nie neguję potrzeby zmian, silnik elektryczny jest sprawnością i bezemisyjnością bezkonkurencyjny, tylko to jeszcze pieśń przyszłości ze względu na wydajność zasilania i infrastrukturę. Do elektryka jak znalazł... https://s3-us-west-1.amazonaws.com/hmt-forum/sound_waves_metal_glass.mp4
Na moje oko - elektryk jest? Jest! A czym ładowany.... to już inna kwestia.... Dzisiaj z Wa-wy do Katowic elektrykiem nie dojedziesz, bo nie ma gdzie po drodze doładować, nie mówiąc o dodatkowym czasie na to. Wyobraźcie sobie ile dodatkowych elektrowni (jakich?) i infrastruktury musiałoby powstać żeby zamienić wszystkie osobowe spaliniaki na elektryki (że o ciężarówkach nie wspomnę). I to we wszystkich krajach, bo przecież ludzie podróżują. A napędzane dieslem maszyny budowlane, a inne? Moim zdaniem zakaz w 2035 jest nierealny...
Mało prawdopodobne? A jak pasażerowie(np zderzenia?) będą nieprzytomni?
Będzie dobrze. Gdyby się okazało, że trzpienie z ułamanego wiertła się jednak wyginają (chwyty czarnych wierteł nie zawsze są tak twarde jak część robocza. Wiertła białe/szlifowane z HSS/ lub kobaltowe/HSS-Co/ są jednolite-mają twardsze chwyty), to radziłbym wstawić w otwory np (przycięte?) igiełki z łożyska igiełkowego (jeśli ich długość 9,8mm jest wystarczająca) albo obcięte z odp. gwintowników. katalog https://www.ltmet.pl/igielki-lozyskowe/
A, przepraszam, to wtedy tak, da się tak nawiercić..
Nie, to zła koncepcja. Dlatego, że wiertło będzie statyczne, a obracał się będzie materiał. Jeśli przesuniesz wiertło 2,4mm od osi obrotu materiału, to najpierw będzie rysować wokół osi obrotu okrąg(jak to widać na Twoim zdjęciu), a jak już uda mu się nieco już zagłębić w materiał, to jego koniec będzie podążał za nawiercanym otworem po okręgu oddalając się od osi konika(i osi zamocowania wiertła) w najdalszym punkcie o 4,8mm. Czyli krótko mówiąc będzie o tyle wyginane przy każdym obrocie. Czym to grozi przy coraz większym zagłębianiu się wiertła nie trzeba chyba wyjaśniać, nie mówiąc o rozbijaniu przez nie samego otworu. (takie coś może udałoby się gdyby wiertło było baaardzo bardzo długie, wtedy kąt jego wygięcia byłby proporcjonalny do jego długości, ale rozbijałby otwór dalej, choć mniej) Jeśli chcesz wywiercić na tokarce niecentryczne otwory, to musisz zdecentrować o żądaną wartość oś obrotu wierconego materiału, czyli krótko mówiąc: - albo zastosować uchwyt (4-szczękowy) z niezależnie ustawianymi szczękami, wtedy możesz ustawiać dowolne przesunięcie osi obrotu, (jak widać na fotkach, tu akurat kostkę) - albo między jedną szczękę 3-szczękowego samocentrujacego uchwytu tokarskiego a materiał podłożyć podkładkę grubości (A) by przesunąć oś obrotu (O) wierconego otworu względem osi symetrii (N) materiału(o średnicy d) o wielkość (e). Podobnie jak robi się to tocząc detal mimośrodowo*. Grubość podkładki A obliczmy ze wzoru : ( https://www.google.com/url?sa=i&url=https%3A%2F%2Fwydawnictwo.not.pl%2FINZ2017%2FZ1%2F2_PYTLAK.pdf&psig=AOvVaw2UcVygP1GHLgUc0AEP4j50&ust=1679529183650000&source=images&cd=vfe&ved=2ahUKEwizgKn0m-79AhUPzSoKHSa5DqUQjhx6BAgAEAs ) gdzie: A - grubość podkładki, e - wielkość przesunięcia od osi symetrii materiału, d- średnica materiału (2r), Drugi symetryczny otwór wykonasz obracając detal w szczękach uchwytu o 180°. * - podobny wzór http://www.homemetalshopclub.org/news/aug03/ecentric_centering.jpg (https://www.cnc.info.pl/jak-z-twardych-szczek-zrobic-miekkie-zataczane-t54975.html)
Nie masz do swojej tokarki podtrzymki ruchomej, a musisz przetoczyć bardzo długi cienki wałek? Jest wyjście:
- 2
wynik tego pomiaru bicia zamocowanego w szczękach uchwytu materiału jest bardzo dobry. Drgania wskazówki w obrębie setki mogą nawet być wynikiem dość długiego ramienia (a co za tym idzie mniej sztywnego mocowania czujnika) + tarcie końcówki o obracający się dość szybko materiał *. Obserwując obrót wiertła zamocowanego w uchwycie nie widać by biło, więc można uznać, że jest w osi wrzeciona i przystawić do drugiego statycznie zamocowanego w koniku. Jednak gdy kamera zniżyła się do mniej więcej poziomu wierteł można zauważyć lekką niewspółosiowość obu - to w koniku jest wyżej niż to w uchwycie. Po wypoziomowaniu i powiększeniu fragmentu obrazu stopklatki daje się to wyraźnie zauważyć. Nie jest to dużo, ale im cieńsze wiertło, tym bardziej będzie naginane w czasie zagłębiania w materiał co może doprowadzić do jego pęknięcia. Być może ten uchyb wynika to z bicia wiertła w szczękach uchwytu wiertarskiego, co niestety dość powszechnie się zdarza zwłaszcza gdy nie jest nowy. Można to sprawdzić obracając go w koniku o 180° - jeśli to to, to operacja powinna dać obraz, że jest teraz poniżej osi wiertła w uchwycie tokarskim. Usunąć to można jedynie zmieniając uchwyt. Ale jeśli obrót uchwytu wiertarskiego nic nie zmieni, to będzie znaczyć, że oś tulei konika jest nieco wyżej niż oś wrzeciona (przy porównywaniu pamiętać o zaciskaniu tulei w korpusie konika!). Pozostanie odpowiednio przeszlifować górę dolnej części konika przy płetwie poprzecznej. * - Tak na przyszłość, to zasadniczo powinno się stosować możliwie małe obroty przy pomiarze, by łatwiej było zauważyć pełną skalę wychyłu wskazówki czujnika. Bo ona i mechanizm który ją napędza też ma jakąś swoją bezwładność, i jeśli obroty są zbyt duże, to nie zdąży się wychylać w pełnym zakresie uchybu, tylko drga w niewielkim zakresie górnej odchyłki (przeskakuje nad "dołkami"), fałszując odczyt rzeczywistego uchybu. I możliwie krótkie mocowanie czujnika, co poprawi sztywność układu.
Prawidłowa nazwa narzędzia do wykonania nakiełków to nawiertak do nakiełków. Ale potocznie w żargonie tokarskim mówi się na nie "nakiełek", bo nazwa "nawiertak" stricte w technice to dość szerokie pojęcie (nie zawsze zgodne z prawidłowym technicznym nazewnictwem), i może być różnego kształtu.. to też "nawiertaki".. Dla informacji- na rysunkach technicznych części możemy spotkać kilka oznaczeń rodzajów nakiełków czasem oznaczone tylko samym symbolem w/g normy ISO6411 lub PN-75/M-02497: A; B; R; z gwintem; (bez pokazanego przekroju), https://www.cnc.info.pl/nakielek-t118674.html
Na statycznym. Do zamocowanego w uchwycie (nieobracającego się) sztywnego wałka/rury przystawiasz czujnik do korpusu uchwytu i naciskając/ciągnąc za wałek w płaszczyźnie w jakiej przystawiłeś czujnik sprawdzasz ile się ugnie. (dobrze jest ciągnąć wagą wędkarską z siłą tak oj 2-5kg, daje to pewien obraz stanu łożysk. Im lżej ciągniesz, a jest ugięcie - tym gorszy luz łożysk) Na filmie poniżej pokazane jest jak się ustawia luz łożysk stożkowych, ale luz kulkowych też analogicznie można sprawdzić, tyle, że luzu kulkowych wyregulować się nie da, i albo zmiana na nowe, albo zmiana na stożkowe i regulacja.
Niestety nie zawsze, wytwórców klonów tego modelu jest w Chinach przynajmniej kilku, i różną też mają jakość. Dla niektórych dystrybutorów są wykonane nieco staranniej niż inne(ale i cena jest zazwyczaj wyższa) np na rynek amerykański dla https://www.grizzly.com/ (7x12"; 7x14") https://www.grizzly.com/products/grizzly-7-x-12-mini-metal-lathe/g8688 ale niestety na napięcie 110V
Są specjalne kleje do ABS-u np https://e-kleje.pl/klej-do-abs-poliweglanu-plexi-polistyrenu-multibond-431-p-151.html?gclid=CjwKCAjw5dqgBhBNEiwA7PryaOO5KXn6D8cwxDF15qiPXGoLapXrudnZPuXuSiK-jy6LXwMJcrRcfRoCcCUQAvD_BwE https://allegro.pl/oferta/klej-do-abs-plexi-pow-trudnosklejalnych-mocny-20g-13341736606 https://allegro.pl/oferta/klej-do-tworzywa-abs-cyjanoakrylowy-primer-budfix-13296074322?bi_s=ads&bi_m=productlisting:desktop:queryandcategory&bi_c=MjFiZTkzOGUtYjZiYy00NzBmLThlZGItZDBjMDM2YTNiZGM5AA&bi_t=ape&referrer=proxy&emission_unit_id=5b8e7fb6-8190-490d-8630-99374509dd3f ale i taki z marketu budowlanego też trzyma https://allegro.pl/oferta/dragon-klej-do-plastiku-50-ml-pmma-abs-pcw-bezbarw-13165292812 Ja do twardych plastików najczęściej używam tego (w Brico Marche) https://motoluka.pl/kleje/114768-technicqll-klej-do-twardych-plastikow-20ml-pcv-abs-pur-tr-eva-5902051000327.html lekko rozpuszcza klejone powierzchnie i jest twardy po sklejeniu. (w ogóle https://www.technicqll.pl/index.php/pl/ ma dobre kleje dedykowane do różnych materiałów) https://allegro.pl/oferta/specjalny-klej-do-pp-plastiku-pe-abs-hdpe-ptfe-8793167084
Zdarzyć się może, że będziemy mieć szeroką deskę do przestrugania, ale dysponujemy tylko wąską ręczną strugarką. Jak to zrobić za jej pomocą pokazuje ten film. Zastąpi też grubościówkę.
